跳转到主内容
HP Pavilion 15 dyl1087nr Screen Replacement
你所需要的
  1. HP Pavilion 15 dyl1087nr Screen Replacement, Laptop Screen: 步骤 1 中的图像 1,3 HP Pavilion 15 dyl1087nr Screen Replacement, Laptop Screen: 步骤 1 中的图像 2,3 HP Pavilion 15 dyl1087nr Screen Replacement, Laptop Screen: 步骤 1 中的图像 3,3
    • Open the laptop so the screen is in an upright position.
    • Use a spudger on the underside of the bezel to release the clips securing it to the screen assembly.
    • Work your way around the entire bezel until the bezel is free.
  2. HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the bezel and set it aside to reveal the laptop screen assembly interior.
    • You will need the bezel for reassembly.
  3. HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 3 中的图像 3,3
    • Use tweezers to remove the double-sided tape underneath the four corners of the display screen.
    • If you tear the tape, it is okay, it will just be moderately more challenging to pull the display screen off from the laptop.
  4. HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 4 中的图像 2,2
    • Flip the display screen over facedown to reveal the tape connecting the screen to the rest of the computer.
  5. HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the tape covering the display cable connector.
    • Use your spudger to detach the display cable connector. First, gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
    • Grip the cable and buckle together and insert the connector fully into its socket.
    • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
    • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
  6. HP Pavilion 15 dyl1087nr Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the old LCD screen and replace it with your new display screen.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Rick Tan
于03/05/24注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-9, Grodsky Spring 2024 CSU Los Angeles, Team 7-9, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G9
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 45
