跳转到主内容
HP Pavilion 15-p Palmrest Replacement
你所需要的
  1. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: 步骤 1 中的图像 1,3 HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: 步骤 1 中的图像 2,3 HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: 步骤 1 中的图像 3,3
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: 步骤 2 中的图像 1,3 HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: 步骤 2 中的图像 2,3 HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: 步骤 2 中的图像 3,3
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Palmrest Replacement, Remove the battery: 步骤 3 中的图像 1,2 HP Pavilion 15-p Palmrest Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: 步骤 4 中的图像 1,3 HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: 步骤 4 中的图像 2,3 HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: 步骤 4 中的图像 3,3
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
  5. HP Pavilion 15-p Palmrest Replacement, Remove the screws under the optical drive: 步骤 5 中的图像 1,1
    • The system used in the guide only came with one screw. If yours came with three, sort accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
  6. HP Pavilion 15-p Palmrest Replacement, Remove the bottom screws: 步骤 6 中的图像 1,1
    • Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • This screw is hidden by a sticker. If lost/damaged, it is cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
  7. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: 步骤 7 中的图像 1,3 HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: 步骤 7 中的图像 2,3 HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: 步骤 7 中的图像 3,3
    • If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  8. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: 步骤 8 中的图像 1,3 HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: 步骤 8 中的图像 2,3 HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: 步骤 8 中的图像 3,3
    • Do not fully remove the palmrest - the power button is still connected to the motherboard.
    • If you are having trouble removing the palmrest, try using a guitar pick.
    • Run a plastic tool around all 3 sides of the palmrest. Once they are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up and disconnect the cables.
    • Once the keyboard and trackpad are disconnected, the palmrest can be lifted up. In some cases, further prying may be needed.
  9. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: 步骤 9 中的图像 1,3 HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: 步骤 9 中的图像 2,3 HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: 步骤 9 中的图像 3,3
    • With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
结论
5等其他人完成本指南。
Nick
于11/10/09注册
88,851 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
5条评论
My power button is bad and my mouse track stopped working. I couldn't find a replacement for it. What can I do?
Trevor Gilbert - 回复
hi where can i source a replacement palm rest assembly for my hp pavilion 15 2015. its the same as the first laptop picture
Oche Ejiga - 回复
You have the US ENG keyboard most likely. I posted the parts list as new steps (762529-001 or 762530-001). Verify it based on the part number sticker to be absolutely sure though but that is likely a match.
Nick -
Hi my hinge broke off and so was some of my speaker. Plus, its making my screen close on its own and I can't keep it still. :( Where can I get a replacement for the palmrest, keyboard, and touchpad? My model for my hp pavillion laptop is: 3C310UA#ABA
thecrowrules1982 - 回复
Parts laptop, or a junk laptop with a bad motherboard (BIOS lock or dead power). The bare part tends to be ~$150+ if it's available and will only get worse as they become hard to find.
Nick -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 47
总计 6,358
