跳转到主内容
HP Pavilion 15 P Series Motherboard Replacement
你所需要的
  1. HP Pavilion 15 P Series Motherboard Replacement, Shutdown Laptop: 步骤 1 中的图像 1,1
    • Before working on the laptop, make sure it is shut down.
  2. HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: 步骤 2 中的图像 1,3 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: 步骤 2 中的图像 2,3 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Pull the locking tab to the right showing a unlocked symbol.
    • Then pull the release tab to the left, releasing the battery.
    • Lift the battery out of its connection.
  3. HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: 步骤 3 中的图像 1,2 HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: 步骤 3 中的图像 2,2
    • Unscrew the single Phillips #0 screw that holds the optical drive in place.
    • Using a spudger push the optical drive out.
    • Pull the optical drive completely out and set it to the side.
  4. HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: 步骤 4 中的图像 1,3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: 步骤 4 中的图像 2,3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: 步骤 4 中的图像 3,3
    • Using a spudger, pry up the rubber cap.
    • Remove the single screw underneath the cap.
    • Slightly lift up on the marked section of the hinge cap. Pull away from the computer to release the cap.
    • Remove the hinge screw.
    • Repeat all steps on the other side.
  5. HP Pavilion 15 P Series Motherboard Replacement, Remove Bottom Screws.: 步骤 5 中的图像 1,1
    • Remove each of the highlighted screws.
    • Note, this screw is sometimes covered by a cap.
    • Remove the silver pan head crew in the optical drive bay.
  6. HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: 步骤 6 中的图像 1,3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: 步骤 6 中的图像 2,3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: 步骤 6 中的图像 3,3
    • Flip your computer back over and open the display. Using a sputter, opening tool, guitar pick, or card pry up on the top case between the frame and itself.
    • Follow all the way around the top case gently, until the keyboard is able to be lifted freely.
    • NOTE* Do not lift the keyboard off until the next step in which we pull the ribbon cable connections.
    • Using your spudger, or prying tool lift the releases for each ribbon cable. *Be cautious when removing and handling ribbon cables as they are very fragile.
    • Lastly, remove the last two ribbon cables located at the top of the keyboard.
  7. HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: 步骤 7 中的图像 1,3 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: 步骤 7 中的图像 2,3 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: 步骤 7 中的图像 3,3
    • Remove each cable and connection to the logic board.
    • Next, remove the screws holding the motherboard to the bottom case.
    • There may be a screw in this area, there was not in the computer I worked on.
    • Remove the screw holding the wifi card in place. Pull the wifi card out.
  8. HP Pavilion 15 P Series Motherboard Replacement, Finish Removing the Mother Board: 步骤 8 中的图像 1,1
    • The hardest connection to remove, this is the cable to the AC/DC power port. Remove it by pulling the outside edges of the connector and wiggling gently.
  9. HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: 步骤 9 中的图像 1,2 HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: 步骤 9 中的图像 2,2
    • Remove the fan by disconnecting the white pin connector and then removing the only Phillips crew holding the fan in place.
    • Now you're ready to put the new logic board in!
结论
8等其他人完成本指南。
help
于07/24/14注册
431 声望
撰写一个指南
团队
Out of a Jam Solutions Out of a Jam Solutions 的会员
Business
2 名成员
创作了3篇指南
3条评论
Thanks for this guide. Apparently the RAM is on the underside of the logic board?
I have a HP 15-P189NA which could do with a RAM upgrade.
Douglas Bateman - 回复
Das Modell 15-P151NG ist etwas anders, hilft trotzdem die Anleitung.
Alex Barblexi - 回复
Ich wäre an dem defekten Mainboard interessiert.
Bernd Dreyer - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 119
总计 15,212
