跳转到主内容
HP Pavilion 14-v062us Screen Replacement
你所需要的
  1. HP Pavilion 14-v062us Screen Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 14-v062us Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Power laptop off and make sure it is not plugged into charger
    • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
  2. HP Pavilion 14-v062us Screen Replacement: 步骤 2 中的图像 1,2 HP Pavilion 14-v062us Screen Replacement: 步骤 2 中的图像 2,2
    • Lift the battery upwards and out from the laptop
  3. HP Pavilion 14-v062us Screen Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Remove rectangular rubber tops with a spudger
    • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
    • Remove plastic edge covering with the blue plastic opening tool.
    • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
  4. HP Pavilion 14-v062us Screen Replacement: 步骤 4 中的图像 1,2 HP Pavilion 14-v062us Screen Replacement: 步骤 4 中的图像 2,2
    • Use Phillips screwdriver #1
    • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
    • Remove the three 7.14 mm PH#1 screws.
    • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
  5. HP Pavilion 14-v062us Screen Replacement: 步骤 5 中的图像 1,2 HP Pavilion 14-v062us Screen Replacement: 步骤 5 中的图像 2,2
    • Remove disc tray
    • Locate screw within computer that is inside of where the disc tray was
    • Using a Phillips #1 screwdriver, unscrew the screw
    • Set laptop down and open laptop so the keyboard is facing you
  6. HP Pavilion 14-v062us Screen Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement: 步骤 6 中的图像 3,3
    • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
    • Pry until you are able to lift entire face and keyboard
    • Only cables should be connecting it underneath
  7. HP Pavilion 14-v062us Screen Replacement: 步骤 7 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement: 步骤 7 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement: 步骤 7 中的图像 3,3
    • Disconnect/ unplug cables using plastic opening tool.
    • Separate the keyboard panel from the laptop with your hands.
    • Turn around the laptop and lay it flat.
  8. HP Pavilion 14-v062us Screen Replacement: 步骤 8 中的图像 1,2 HP Pavilion 14-v062us Screen Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
    • Only use a metal spudger as a last resort
  9. HP Pavilion 14-v062us Screen Replacement: 步骤 9 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement: 步骤 9 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement: 步骤 9 中的图像 3,3
    • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
  10. HP Pavilion 14-v062us Screen Replacement, Screen: 步骤 10 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement, Screen: 步骤 10 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement, Screen: 步骤 10 中的图像 3,3
    • Using the spudger, wedge tool in between screen and laptop
    • Only use a metal spudger as a last resort. A regular black nylon spudger or a plastic opening tool should be used whenever possible
    • Pry open screen with spudger and your hands
  11. HP Pavilion 14-v062us Screen Replacement: 步骤 11 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement: 步骤 11 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement: 步骤 11 中的图像 3,3
    • Remove the four 2.86 mm JIS#0 screws from each corner of the silver frame that is holding the digitizer.
  12. HP Pavilion 14-v062us Screen Replacement: 步骤 12 中的图像 1,2 HP Pavilion 14-v062us Screen Replacement: 步骤 12 中的图像 2,2
    • Locate the white and brown wiring that connects to the digitizer and the screen.
    • Cut through the clear part of tape attached to the brown latch and white wiring.
    • Disconnect the wiring, by lifting the brown latch with the blue plastic opening tool and pulling the white wire at the same time.
    • Lift off the digitizer. If you need to replace the digitizer stop here and replace this part.
    • If you need to replace the screen, then continue
  13. HP Pavilion 14-v062us Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the four 5.66 mm PH#0 from under the keyboard near the hinges.
  14. HP Pavilion 14-v062us Screen Replacement: 步骤 14 中的图像 1,3 HP Pavilion 14-v062us Screen Replacement: 步骤 14 中的图像 2,3 HP Pavilion 14-v062us Screen Replacement: 步骤 14 中的图像 3,3
    • Wedge spudger in between screen and back of computer
    • Detach screen
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 1,351
