跳转到主内容
HP Pavilion 14-v062us Fan Replacement
你所需要的
  1. HP Pavilion 14-v062us Fan Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Power laptop off and make sure it is not plugged into charger
    • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
  2. HP Pavilion 14-v062us Fan Replacement: 步骤 2 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement: 步骤 2 中的图像 2,2
    • Lift the battery upwards and out from the laptop
  3. HP Pavilion 14-v062us Fan Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion 14-v062us Fan Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion 14-v062us Fan Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Remove rectangular rubber tops with a spudger
    • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
    • Remove plastic edge covering with the blue plastic opening tool.
    • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
  4. HP Pavilion 14-v062us Fan Replacement: 步骤 4 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement: 步骤 4 中的图像 2,2
    • Use Phillips screwdriver #1
    • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
    • Remove the three 7.14 mm PH#1 screws.
    • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
  5. HP Pavilion 14-v062us Fan Replacement: 步骤 5 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement: 步骤 5 中的图像 2,2
    • Remove disc tray
    • Locate screw within computer that is inside of where the disc tray was
    • Using a Phillips #1 screwdriver, unscrew the screw
    • Set laptop down and open laptop so the keyboard is facing you
  6. HP Pavilion 14-v062us Fan Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-v062us Fan Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-v062us Fan Replacement: 步骤 6 中的图像 3,3
    • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
    • Pry until you are able to lift entire face and keyboard
    • Only cables should be connecting it underneath
  7. HP Pavilion 14-v062us Fan Replacement: 步骤 7 中的图像 1,3 HP Pavilion 14-v062us Fan Replacement: 步骤 7 中的图像 2,3 HP Pavilion 14-v062us Fan Replacement: 步骤 7 中的图像 3,3
    • Disconnect/ unplug cables using plastic opening tool.
    • Separate the keyboard panel from the laptop with your hands.
    • Turn around the laptop and lay it flat.
  8. HP Pavilion 14-v062us Fan Replacement: 步骤 8 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
    • Only use a metal spudger as a last resort
  9. HP Pavilion 14-v062us Fan Replacement: 步骤 9 中的图像 1,3 HP Pavilion 14-v062us Fan Replacement: 步骤 9 中的图像 2,3 HP Pavilion 14-v062us Fan Replacement: 步骤 9 中的图像 3,3
    • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
  10. HP Pavilion 14-v062us Fan Replacement, Fan: 步骤 10 中的图像 1,3 HP Pavilion 14-v062us Fan Replacement, Fan: 步骤 10 中的图像 2,3 HP Pavilion 14-v062us Fan Replacement, Fan: 步骤 10 中的图像 3,3
    • Remove all 6 screws (5.65 mm) from the motherboard, using Phillips screwdriver J0
    • There will be a silver covering (in a z shape) that needs to be removed using black tweezers or a plastic opening tool
  11. HP Pavilion 14-v062us Fan Replacement: 步骤 11 中的图像 1,1
    • Remove the two 5.66mm screws from the motherboard using Phillips head screwdriver J0
  12. HP Pavilion 14-v062us Fan Replacement: 步骤 12 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement: 步骤 12 中的图像 2,2
    • Remove entire motherboard from the laptop
    • Turn over and remove the single 5.63mm screw using a Phillips head screwdriver J0.
  13. HP Pavilion 14-v062us Fan Replacement: 步骤 13 中的图像 1,2 HP Pavilion 14-v062us Fan Replacement: 步骤 13 中的图像 2,2
    • Remove wiring with plastic opening tool
    • Remove fan
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,334
