简介
This guide is for the replacement of the display assembly of an HP Pavilion 14-n018us.
It will show the disassembly steps needed to remove and replace a laptop screen if it is broken or cracked without having to replace the entire laptop, saving money for the user.
你所需要的
Press the two tabs on the back of the laptop inward to release the battery.
Pull the battery straight out slowly and firmly.
Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
Use the plastic spudger and loosen the display away from the back of the screen.
Continue to use the spudger to detach the small plastic detents holding the screen in place.
Disconnect the display cable and remove the screen.
