跳转到主内容
HP Pavilion 14-n018us Display Assembly Replacement
你所需要的
  1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 14-n018us Display Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: 步骤 2 中的图像 1,3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: 步骤 2 中的图像 2,3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: 步骤 2 中的图像 3,3
    • Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
    • Use the plastic spudger and loosen the display away from the back of the screen.
    • Continue to use the spudger to detach the small plastic detents holding the screen in place.
    • Disconnect the display cable and remove the screen.
  3. HP Pavilion 14-n018us Display Assembly Replacement: 步骤 3 中的图像 1,1
    • The screen can now be reassembled!
结论
Michael Hollister
于10/01/21注册
253 声望
创作了3篇指南
团队
Casper College, Team 1-1, Lareau Fall 2021 Casper College, Team 1-1, Lareau Fall 2021 的会员
CASC-LAREAU-F21S1G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 205
