跳转到主内容
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
你所需要的
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 步骤 2 中的图像 2,2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 步骤 3 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 步骤 3 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: 步骤 3 中的图像 3,3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
结论
2等其他人完成本指南。
Joe Kennedy
于01/23/17注册
231 声望
创作了2篇指南
团队
Cal Poly, Team 22-8, Maness Winter 2017 Cal Poly, Team 22-8, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G8
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 456
