跳转到主内容
HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement
你所需要的
  1. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 2 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 3 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 3 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 3 中的图像 3,3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
  4. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 2,2
    • Locate these seven 5mm circled screws on the panel that was under the keyboard.
    • Remove the screws with a Phillips Head #1 Screwdriver.
  5. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 5 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 5 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Locate the ribbon cable located at the top of the keyboard area.
    • At the cable base, lift the white tab with a fingernail and then gently pull on the blue tab of the cable to release it.
  6. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 6 中的图像 3,3
    • Locate the ribbon cable just above the touchpad.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
  7. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 7 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 7 中的图像 2,2
    • Locate these eight 7mm screws on the bottom of the laptop.
    • Remove using a Philips Head #1 Screwdriver.
  8. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Flip the computer back over, and using the metal spudger, remove the plastic palm rest assembly.
    • Go little by little around the edge and carefully pry off the plastic palm rest assembly.
  9. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 9 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 9 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 9 中的图像 3,3
    • Flip the plastic flap to unattach the metal strip located at the bottom left corner.
    • The headphone jack is attached to this cable.
  10. HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 10 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 10 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Headphone Jack Replacement: 步骤 10 中的图像 3,3
    • Remove the circled screw located at the bottom left using a Phillips #1 Screwdriver.
    • You can now disconnect the headphone jack piece.
结论
2等其他人完成本指南。
Joe Kennedy
于01/23/17注册
231 声望
创作了2篇指南
团队
Cal Poly, Team 22-8, Maness Winter 2017 Cal Poly, Team 22-8, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G8
4 名成员
创作了5篇指南
一条评论
It would be great if somebody could help me with the issue I’m facing. My laptop is an HP Pavilion Sleekbook14b030tu, the headphone jack doesn’t work always I mean it does not detect my earphones or any earphones for that matter. I contacted HP and they told me a method to fix this, they claim that this is caused by a power surge so holding the power button and the mute switch for 20 seconds after shutting down should resolve the issue. It worked a few times but now its gone completely . Do I have to replace it or what do I do to fix it permanently ?
Arnold Clifton - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 897
