跳转到主内容
HP Pavilion 14-c015dx Chromebook Fan Replacement
你所需要的
  1. HP Pavilion 14-c015dx Chromebook Fan Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 2 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 2 中的图像 2,2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 3 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 3 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 3 中的图像 3,3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
  4. HP Pavilion 14-c015dx Chromebook Fan Replacement, Fan: 步骤 4 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Fan Replacement, Fan: 步骤 4 中的图像 2,2
    • Locate these seven circled screws.
    • Remove the seven 5mm screws using the Phillips Head #1 Screwdriver.
  5. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 5 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 5 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 5 中的图像 3,3
    • Locate the ribbon cable near the top of the keyboard area.
    • At the cable base, lift the white tab with a fingernail and then pull on the blue section of the cable to release it.
  6. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 6 中的图像 3,3
    • Locate the ribbon cable just above the touchpad.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
  7. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 7 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 7 中的图像 2,2
    • Remove the eight 7mm screws with a Philips Head #1 screwdriver.
  8. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the plastic palm rest assembly using the metal spudger.
    • Go little by little around the edge and carefully pry off the plastic palm rest assembly.
  9. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 9 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 9 中的图像 2,2
    • Locate the protective yellow tape that is covering two wires in between the fan and the motherboard.
    • Remove this yellow tape.
    • Some laptops may not have this protective yellow tape. If yours does not it does not matter, just skip this step.
  10. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 10 中的图像 1,2 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 10 中的图像 2,2
    • Locate the single remaining screw holding the fan in place.
    • Remove the 5 mm screw using a Phillips Head #1 Screw Driver.
  11. HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 11 中的图像 1,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 11 中的图像 2,3 HP Pavilion 14-c015dx Chromebook Fan Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the wires that connect the fan to the motherboard.
    • Remove this wire connector using the tweezers.
    • You can now completely remove the fan from the laptop.
结论
William Busby
于01/23/17注册
234 声望
创作了2篇指南
团队
Cal Poly, Team 22-8, Maness Winter 2017 Cal Poly, Team 22-8, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G8
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 390
