跳转到主内容
HP Pavilion 14-b120dx CPU Cooling Fan Replacement
你所需要的
  1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 2 中的图像 1,3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 2 中的图像 2,3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 4 中的图像 1,2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: 步骤 5 中的图像 1,2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: 步骤 5 中的图像 2,2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 6 中的图像 3,3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 7 中的图像 1,1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: 步骤 8 中的图像 1,2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: 步骤 8 中的图像 2,2
    • Locate the fan in the upper left hand corner of the laptop.
    • Remove the cable connecting the fan to the motherboard.
    • Be sure not to damage the motherboard or the connecting cable. Carefully apply force to remove the cable.
  9. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 9 中的图像 1,2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 9 中的图像 2,2
    • Unscrew the 3 6.0 mm screws holding the fan with a Phillips #0 head screwdriver.
  10. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: 步骤 10 中的图像 1,1
    • Remove the fan by pulling upward and to the right.
结论
另外一个人完成了本指南。
Erin Lavalla
于10/18/16注册
458 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,291
