跳转到主内容
HP Pavilion 14-b120dx Audio Port/USB Drive Replacement
你所需要的
  1. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: 步骤 5 中的图像 1,2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: 步骤 5 中的图像 2,2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 6 中的图像 3,3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 7 中的图像 1,1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: 步骤 8 中的图像 1,2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: 步骤 8 中的图像 2,2
    • Carefully disconnect the cable connecting the ports to the motherboard from the right side.
  9. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 9 中的图像 1,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 9 中的图像 2,3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 9 中的图像 3,3
    • Remove the two 6.0 mm screws from the ports.
  10. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 10 中的图像 1,2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: 步骤 10 中的图像 2,2
    • Push the ports to the left and lift upward to remove them safely.
结论
2等其他人完成本指南。
Erin Lavalla
于10/18/16注册
458 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G4
3 名成员
创作了6篇指南
2条评论
where can I find the replacement part?
edwin abraham - 回复
Hello, first I just wanted to say thank you so much for writing these guides! You’re a super hero…. now then, I find myself in quite a pickle. I have an HP 15-b123cl with a screen that’s broken. I need to resolder one of the connectors. I have a picture that will show you which connector I need to fix, but I can’t post a picture in this comment section… all I need is a picture of the display connector on the top left of the motherboard. I even checked ifixit for some way of messaging you directly, but no luck :(… all I can think to do is give you my personal email address and hope that you send me something! Anyways… THANKS ERIN
Ethan
ejstepanianATgmail.com
Ethan Stepanian - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 814
