跳转到主内容
HP Pavilion 14-b015dx Hard Drive Replacement
你所需要的
  1. HP Pavilion 14-b015dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Hard Drive Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Hard Drive Replacement, Palm Rest: 步骤 8 中的图像 1,1
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 10 中的图像 1,1
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Once all clips have been undone lift the palm rest away from the laptop.
  12. HP Pavilion 14-b015dx Hard Drive Replacement, Hard Drive: 步骤 12 中的图像 1,1
    • Gently unhook the ribbon cable blocking the hard drive by lifting the locking bar with a plastic opening tool.
  13. HP Pavilion 14-b015dx Hard Drive Replacement: 步骤 13 中的图像 1,1
    • Remove the 2 screws securing the hard drive
    • Lift the hard drive up and remove the connector on the end using the blue opening tool.
结论
Gregory Bridge
于10/24/17注册
623 声望
创作了6篇指南
团队
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 的会员
UMASSD-ISAACSON-F17S1G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 2,145
