简介
In this guide, you will find the necessary steps to remove the hard drive in an HP Pavilion 14-b015dx laptop. This is useful for increasing storage on your laptop or if your storage device is faulty.
Signs of a faulty hard drive can include frequent error messages or system crashes, strange sounds, slow performance, overheating, and corrupted data, files, and folders.
This guide requires the removal of the keyboard and the top case of the laptop. Before starting this process, the laptop must be unplugged and powered off completely.
你所需要的
Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
Gently unhook the ribbon cable blocking the hard drive by lifting the locking bar with a plastic opening tool.
