跳转到主内容
HP Pavilion 13-s128nr Back Panel Replacement
你所需要的
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: 步骤 2 中的图像 1,1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: 步骤 3 中的图像 1,2 HP Pavilion 13-s128nr Back Panel Replacement: 步骤 3 中的图像 2,2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 781
