跳转到主内容
HP Pavilion 11-n010dx Hard Drive Replacement
你所需要的
  1. HP Pavilion 11-n010dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 11-n010dx Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Hard Drive Replacement, Hard Drive: 步骤 8 中的图像 1,1
    • Use the Phillips #0 to remove the three 3mm screws holding the hard drive in place.
  9. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 9 中的图像 1,2 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Carefully lift the hard drive out of place using the tag.
  10. HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 10 中的图像 1,3 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 10 中的图像 2,3 HP Pavilion 11-n010dx Hard Drive Replacement: 步骤 10 中的图像 3,3
    • Gently pull on the cable connector to disconnect the hard drive from your device.
结论
5等其他人完成本指南。
Joseph Lintz
于09/15/16注册
915 声望
创作了5篇指南
团队
USF Tampa, Team 11-5, Blackwell Fall 2016 USF Tampa, Team 11-5, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G5
3 名成员
创作了5篇指南
2条评论
Thanks a lot Joseph ! Works well for the model 11-n000nf !
Nicolas - 回复
Thanks Joseph-I was able to get it open, disconnect the battery and ordered a new battery. We’ll see if this corrects the problem. Computer was sleeping for over a year. Thank you for your pictures and easy to follow instructions.
Beverlyn - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 5,485
