跳转到主内容
HP Pavilion 11-n010dx Bottom Case Replacement
你所需要的
  1. HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 1,2 HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
    • Use Phillips #0 to remove four 9mm screws.
    • Use Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Bottom Case Replacement: 步骤 2 中的图像 1,3 HP Pavilion 11-n010dx Bottom Case Replacement: 步骤 2 中的图像 2,3 HP Pavilion 11-n010dx Bottom Case Replacement: 步骤 2 中的图像 3,3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Bottom Case Replacement: 步骤 3 中的图像 1,2 HP Pavilion 11-n010dx Bottom Case Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
结论
另外一个人完成了本指南。
Joseph Lintz
于09/15/16注册
915 声望
创作了5篇指南
团队
USF Tampa, Team 11-5, Blackwell Fall 2016 USF Tampa, Team 11-5, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,376
