简介
If the bottom case of your device become cracked or damaged, this guide will show you how to replace it.
你所需要的
Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
Use Phillips #0 to remove four 9mm screws.
Use Phillips #0 to remove seven 6mm screws.
即将完成!
结论
另外一个人完成了本指南。
