跳转到主内容
HP Pavilion 11 x360 Keyboard Replacement
你所需要的
  1. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: 步骤 1 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: 步骤 1 中的图像 2,2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: 步骤 2 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: 步骤 2 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: 步骤 2 中的图像 3,3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Keyboard Replacement, Detach Cable: 步骤 3 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Detach Cable: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Keyboard Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Keyboard Replacement: 步骤 5 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 5 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Remove the battery.
  8. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: 步骤 8 中的图像 1,1
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Cable: 步骤 9 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Cable: 步骤 9 中的图像 2,2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Keyboard Replacement, Remove Hard Drive: 步骤 10 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Remove Hard Drive: 步骤 10 中的图像 2,2
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Keyboard Replacement: 步骤 11 中的图像 1,1
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Keyboard Replacement: 步骤 12 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 12 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 12 中的图像 3,3
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Keyboard Replacement: 步骤 13 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 13 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 13 中的图像 3,3
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Wireless Card: 步骤 14 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Wireless Card: 步骤 14 中的图像 2,2
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: 步骤 15 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: 步骤 15 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: 步骤 15 中的图像 3,3
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Webcam Cable: 步骤 16 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Webcam Cable: 步骤 16 中的图像 2,2
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: 步骤 17 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: 步骤 17 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: 步骤 17 中的图像 3,3
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Power Button Board: 步骤 18 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Power Button Board: 步骤 18 中的图像 2,2
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Power Connector Cable: 步骤 19 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Power Connector Cable: 步骤 19 中的图像 2,2
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Speaker Cable: 步骤 20 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Disconnect Speaker Cable: 步骤 20 中的图像 2,2
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: 步骤 21 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: 步骤 21 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: 步骤 21 中的图像 3,3
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Keyboard Replacement: 步骤 22 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement: 步骤 22 中的图像 2,2
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Keyboard Replacement: 步骤 23 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 23 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 23 中的图像 3,3
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Keyboard Replacement: 步骤 24 中的图像 1,1
    • Remove the RAM.
  25. HP Pavilion 11 x360 Keyboard Replacement: 步骤 25 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement: 步骤 25 中的图像 2,2
    • Lift up the heat sink to remove it from the motherboard.
  26. HP Pavilion 11 x360 Keyboard Replacement, Detach Keyboard: 步骤 26 中的图像 1,2 HP Pavilion 11 x360 Keyboard Replacement, Detach Keyboard: 步骤 26 中的图像 2,2
    • Remove the fifteen 3mm screws connected directly to the keyboard using the PH0 screwdriver.
    • Remove the 3mm screw under the keyboard cable using the PH0 screwdriver.
  27. HP Pavilion 11 x360 Keyboard Replacement, Remove Power Button Board: 步骤 27 中的图像 1,1
    • Remove the two 3mm screws attached to the power button board.
    • Lift out power button board.
  28. HP Pavilion 11 x360 Keyboard Replacement: 步骤 28 中的图像 1,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 28 中的图像 2,3 HP Pavilion 11 x360 Keyboard Replacement: 步骤 28 中的图像 3,3
    • Lift keyboard out.
结论
9等其他人完成本指南。
Natalie
于01/22/15注册
934 声望
创作了4篇指南
团队
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G9
4 名成员
创作了8篇指南
3条评论
Best guide. I just ordered keypad for my laptop. Thank you very much for sharing this!
ashumicro - 回复
I just replaced my keyboard and everything was exactly like the guide. Worked perfectly.
Robert Young - 回复
Hello, I'm the computer tech for a school, we have about 500 HP Probook x360 11 G1 EE, and often the key pop out and the hinge are broken, not the key. Where can I buy a bunch (like 25+) of hinges only.
XAVIER FRETARD - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 13,178
