当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Press down on the two plastic hinges to remove the upper portion of printer.
Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
Rotate the printer so the paper tray is facing towards you.
Gently lift the scanner tray up and away from the printer.
Press the gray plastic tabs inward to release the tabs from the printer.
Returning to the back of the printer, remove the scanner from the back hinges.
With pressure applied, the scanner will detach easily.
Gently grasp and unplug the two white ribbon cables from the printer body.
Be sure to grasp the cable at the connector and not to pull on the wires themselves.
Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
Be sure to grasp the white connector and not to pull on the wires themselves.
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
取消:我没有完成这个指南。
另外一个人完成了本指南。
bpu70241.pdf
PDF - 6.06 mb
与16其他贡献者
于04/12/11注册
153 声望
创作了3篇指南
徽章: 8
+ 5更多徽章
CPSU-MANESS-S11S12G31
5 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 11
总计 5,773
