跳转到主内容
HP Omni 10 Speaker Replacement
你所需要的
  1. HP Omni 10  Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10  Speaker Replacement: 步骤 2 中的图像 1,1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10  Speaker Replacement: 步骤 3 中的图像 1,1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10  Speaker Replacement: 步骤 4 中的图像 1,2 HP Omni 10  Speaker Replacement: 步骤 4 中的图像 2,2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10  Speaker Replacement: 步骤 5 中的图像 1,2 HP Omni 10  Speaker Replacement: 步骤 5 中的图像 2,2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10  Speaker Replacement, Micro Card Reader: 步骤 6 中的图像 1,1
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10  Speaker Replacement: 步骤 7 中的图像 1,1
    • Lift and remove micro card reader board.
  8. HP Omni 10  Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    • Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
  9. HP Omni 10  Speaker Replacement: 步骤 9 中的图像 1,2 HP Omni 10  Speaker Replacement: 步骤 9 中的图像 2,2
    • Pull the black and white wire connector up to disconnect it.
  10. HP Omni 10  Speaker Replacement: 步骤 10 中的图像 1,2 HP Omni 10  Speaker Replacement: 步骤 10 中的图像 2,2
    • Pull the red and black wire connector up to disconnect it.
  11. HP Omni 10  Speaker Replacement: 步骤 11 中的图像 1,1
    • Lift the speaker set out of their sockets.
    • The speakers will also be attached via adhesive. They may be difficult to remove by hand.
  12. HP Omni 10  Speaker Replacement: 步骤 12 中的图像 1,1
    • Unhook the left speaker's connector wire to fully remove it from the device.
结论
另外一个人完成了本指南。
Alex Miller
于10/11/16注册
345 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Leahy Fall 2016 USF Tampa, Team 1-1, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G1
3 名成员
创作了10篇指南
一条评论
its order when i will get it please candly I request
Abdul Raheem - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 592
