跳转到主内容
HP Omen 15-ce198wm Battery Replacement
你所需要的
  1. HP Omen 15-ce198wm Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Omen 15-ce198wm Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the laptop with the bottom facing upwards.
    • Remove eight black 4.7 mm screws using a Phillips #1 screwdriver.
    • Loosen the two captive screws on the bottom of the laptop using a Phillips #1 screwdriver.
  2. HP Omen 15-ce198wm Battery Replacement: 步骤 2 中的图像 1,1
    • Insert an opening tool or a pick between the bottom panel and your computer, and then push down to pull it up.
    • Repeat the step above across every edge, so the panel lifts up completely.
    • I like to start from the rear, as shown in the picture, since there's a wider gap there.
    • You might have to use force to push it open, but always be gentle with your laptop.
  3. HP Omen 15-ce198wm Battery Replacement: 步骤 3 中的图像 1,3 HP Omen 15-ce198wm Battery Replacement: 步骤 3 中的图像 2,3 HP Omen 15-ce198wm Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the four 5.7 mm screws from the battery using a Phillips #1 screwdriver.
    • Use your hands to lift the battery out of the laptop.
    • You may need to push the battery inside a bit to get it out from the clips.
  4. HP Omen 15-ce198wm Battery Replacement: 步骤 4 中的图像 1,2 HP Omen 15-ce198wm Battery Replacement: 步骤 4 中的图像 2,2
    • To install the new battery, simply line up the clips and push them down.
结论
To reassemble your device, follow these instructions in reverse order. Overall, it's an easy process. Most of the estimated time is just trying to remove the bottom panel from the laptop.
5等其他人完成本指南。
Henry Li Li
于03/20/22注册
245 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-36, Briggs Spring 2022 CSU Los Angeles, Team 4-36, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S4G36
1 名成员
创作了1篇指南
3条评论
this is misleading and lying. You made me buy a $50 battery I don't need because you said to buy the ifixit battery. The 15-ce198wm uses a different battery. Unacceptable.
Christian Carter - 回复
Hi, Christian, I'm really sorry for my mistake. When I wrote it, I was just trying to get the assignment done for my class. I never thought that people would actually follow my guide. Seeing the image of my battery and the battery linked, I can clearly see the mistake I made, as the models don't match. I'm not sure what iFixit's policies are, but I hope you can get a refund. Again, I'm really sorry for my oversight, and I will be fixing this guide so it doesn't happen again.
Henry Li Li - 回复
Fantastic instructions with pictures. I’ve never seen the inside of my laptop before. After viewing your instructions, it gave me the confidence to complete the install. Thank you!!!
James Shelnutt - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 69
总计 1,589
