The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
After removing all 5 screws, the fans are still connected with the system through 2 cables.
Carefully pull the fan cables out of the connectors on the motherboard.
Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
