跳转到主内容
HP Omen 15-ax243dx Keyboard Replacement
你所需要的
  1. HP Omen 15-ax243dx Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
    Isn’t the plastic plug toward the center, and screw beneath it, a problem?
    risorcurt - 回复
    There is no screw under the center plug, the bottom is just held on by clips after all 10 screws have been removed
    Nigel Bancroft -
  2. HP Omen 15-ax243dx Keyboard Replacement: 步骤 2 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Keyboard Replacement: 步骤 3 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Keyboard Replacement: 步骤 4 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 4 中的图像 2,2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Keyboard Replacement, Hard-Drive: 步骤 5 中的图像 1,1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Keyboard Replacement: 步骤 6 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 6 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 6 中的图像 3,3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Keyboard Replacement: 步骤 8 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 8 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 8 中的图像 3,3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
  9. HP Omen 15-ax243dx Keyboard Replacement, Screen: 步骤 9 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement, Screen: 步骤 9 中的图像 2,2
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #00 Phillips screwdriver head.
    • Be cautious of where the screws come out from, some will only fit in the same location.
  10. HP Omen 15-ax243dx Keyboard Replacement: 步骤 10 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 10 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 10 中的图像 3,3
    • Remove the tape holding the wires down
    • Disconnect the wires from the wifi chip
    • When removing the wires from the wifi chip, be careful to not damage the connectors.
  11. HP Omen 15-ax243dx Keyboard Replacement: 步骤 11 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 11 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 11 中的图像 3,3
    • Flip the switch up that holds the screen cable in place
    • Lift up and pull back the cable from the insert
  12. HP Omen 15-ax243dx Keyboard Replacement: 步骤 12 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 12 中的图像 2,2
    • Lift the base of the device up to separate the hinges from the body of the device
  13. HP Omen 15-ax243dx Keyboard Replacement: 步骤 13 中的图像 1,1
    • Slide the base of the device out from under the hinges
    • The screen can now be replaced
  14. HP Omen 15-ax243dx Keyboard Replacement, Ventilation Fans: 步骤 14 中的图像 1,1
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  15. HP Omen 15-ax243dx Keyboard Replacement: 步骤 15 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 15 中的图像 2,2
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
    I'm facing difficulties when trying to disconnect the fan cable from the motherboard .. It does seem like it's stuck .. How can I take it apart, do I need noose pliers or other tools ?’
    Hamza AF - 回复
  16. HP Omen 15-ax243dx Keyboard Replacement: 步骤 16 中的图像 1,1
    • The fans can now be removed from the device.
  17. HP Omen 15-ax243dx Keyboard Replacement, Speaker: 步骤 17 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement, Speaker: 步骤 17 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement, Speaker: 步骤 17 中的图像 3,3
    • Disconnect all the ribbon cables highlighted.
    • Be sure to use the plastic opening tool when flipping the switches up on the cable connectors.
  18. HP Omen 15-ax243dx Keyboard Replacement: 步骤 18 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 18 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 18 中的图像 3,3
    • Unplug the wire the connects to the speakers.
  19. HP Omen 15-ax243dx Keyboard Replacement: 步骤 19 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 19 中的图像 2,2
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #0 Phillips screwdriver.
  20. HP Omen 15-ax243dx Keyboard Replacement: 步骤 20 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 20 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 20 中的图像 3,3
  21. HP Omen 15-ax243dx Keyboard Replacement: 步骤 21 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 21 中的图像 2,2
    • Unscrew the two 1.2 mm screws holding the motherboard to the front panel using the same screwdriver.
  22. HP Omen 15-ax243dx Keyboard Replacement: 步骤 22 中的图像 1,1
    • Lift the back of the motherboard up then slide the audio cable out between the heatsink and motherboard
  23. HP Omen 15-ax243dx Keyboard Replacement: 步骤 23 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 23 中的图像 2,2
    • Lift the back of the motherboard up again and remove the charging adapter.
    • This wire is located in a tight spot. Pull it straight out and do not bend it, this will cause irreparable damage to the device.
  24. HP Omen 15-ax243dx Keyboard Replacement: 步骤 24 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 24 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 24 中的图像 3,3
    • Slowly lift up the back of the motherboard.
    • The board is friction fit at the rotation point. Be careful to lift the board around this point.
    • The board will now lift out of the device.
  25. HP Omen 15-ax243dx Keyboard Replacement: 步骤 25 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 25 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 25 中的图像 3,3
    • Lift up the keyboard panel of the device and set it back down.
    • The speaker in the top left hand corner can be taken out of its place.
  26. HP Omen 15-ax243dx Keyboard Replacement: 步骤 26 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 26 中的图像 2,2
    • Remove the tape between the two speakers
    • The left speaker can now be removed.
    • The speakers can be disposed of if needed now.
  27. HP Omen 15-ax243dx Keyboard Replacement, Keyboard: 步骤 27 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement, Keyboard: 步骤 27 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement, Keyboard: 步骤 27 中的图像 3,3
    • Use the opening tool to flip the switch that holds the cable to the power button.
    • Lift the cable out of the connector
  28. HP Omen 15-ax243dx Keyboard Replacement: 步骤 28 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 28 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 28 中的图像 3,3
    • Unscrew the two 1.2 mm #00 Phillips head screws that hold the board in.
    • This can now be lifted straight out of the device.
  29. HP Omen 15-ax243dx Keyboard Replacement: 步骤 29 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 29 中的图像 2,2
    • Unscrew the 1.2 mm #00 Phillips head screw that holds the power button into place.
    • This can be lifted out of the device
  30. HP Omen 15-ax243dx Keyboard Replacement: 步骤 30 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 30 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 30 中的图像 3,3
    • Unscrew the three 1.2 mm #00 Phillips head screws that hold in the plate below the trackpad.
    • This can be lifted out of the device.
  31. HP Omen 15-ax243dx Keyboard Replacement: 步骤 31 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 31 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 31 中的图像 3,3
    • Lift up the clear plastic that covers the top three screws
    • Use a size #00 Phillips head screw driver to remove the three 1.2 mm screws
    • The trackpad can now be removed from the device.
  32. HP Omen 15-ax243dx Keyboard Replacement: 步骤 32 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 32 中的图像 2,2
    • The keyboard can now be slid from underneath the hinges.
    • The keyboard can be disposed of is needed.
    I don't understand how the keyboard comes out.
    Jennifer James - 回复
结论
3等其他人完成本指南。
Dean Lee
于10/19/17注册
360 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G7
3 名成员
创作了7篇指南
6条评论
Do you have a link to buy the replacement keyboard?
Seth Norton - 回复
How do you take apart the keyboard compartment to replace the keyboard?
corbycobb - 回复
Very useful tutorial, thanks !
Hugo - 回复
Very useful tutorial, thanks you so much.
Ata Akkaya - 回复
If you didn't buy a keyboard yet, DON'T!
I followed this guide only to learn at the end that you CANNOT replace just the keyboard (but you CAN put a new keyboard in; keep reading). I specifically bought a keyboard after seeing this guide, and when I got it all taken apart, I learned I wasted my money and time.
This guide should make a correction at the beginning saying that you need MORE than just the keyboard!!!
You can install a new keyboard, but you need to REPLACE THE ENTIRE KEYBOARD COVER as one entire unit: speaker grill, touchpad, etc.
HP routinely designs things to screw customers, and this is a perfect example of it.
The part you need is #859735-001 (red backlit) or #905118-001 (green backlit). Depending where you buy it and how long you want to wait, it'll cost you probably 50 to 100 bucks (China-sourced). There is an unlit keyboard part, IDK the number. Or, buy the HP official part for a lot more, if you can find it.
Good luck!
Eric - 回复
omg i did this too. this was such a waste of time. it should be called the keyboard + cover disposal guide.
Stekstrom -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 76
总计 12,640
