跳转到主内容
HP Omen 15-ax243dx Keyboard Replacement
你所需要的
  1. HP Omen 15-ax243dx Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Keyboard Replacement: 步骤 2 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Keyboard Replacement: 步骤 3 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Keyboard Replacement: 步骤 4 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 4 中的图像 2,2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Keyboard Replacement, Hard-Drive: 步骤 5 中的图像 1,1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Keyboard Replacement: 步骤 6 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 6 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 6 中的图像 3,3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Keyboard Replacement: 步骤 8 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 8 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 8 中的图像 3,3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
  9. HP Omen 15-ax243dx Keyboard Replacement, Screen: 步骤 9 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement, Screen: 步骤 9 中的图像 2,2
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #00 Phillips screwdriver head.
    • Be cautious of where the screws come out from, some will only fit in the same location.
  10. HP Omen 15-ax243dx Keyboard Replacement: 步骤 10 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 10 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 10 中的图像 3,3
    • Remove the tape holding the wires down
    • Disconnect the wires from the wifi chip
    • When removing the wires from the wifi chip, be careful to not damage the connectors.
  11. HP Omen 15-ax243dx Keyboard Replacement: 步骤 11 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 11 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 11 中的图像 3,3
    • Flip the switch up that holds the screen cable in place
    • Lift up and pull back the cable from the insert
  12. HP Omen 15-ax243dx Keyboard Replacement: 步骤 12 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 12 中的图像 2,2
    • Lift the base of the device up to separate the hinges from the body of the device
  13. HP Omen 15-ax243dx Keyboard Replacement: 步骤 13 中的图像 1,1
    • Slide the base of the device out from under the hinges
    • The screen can now be replaced
  14. HP Omen 15-ax243dx Keyboard Replacement, Ventilation Fans: 步骤 14 中的图像 1,1
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  15. HP Omen 15-ax243dx Keyboard Replacement: 步骤 15 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 15 中的图像 2,2
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
  16. HP Omen 15-ax243dx Keyboard Replacement: 步骤 16 中的图像 1,1
    • The fans can now be removed from the device.
  17. HP Omen 15-ax243dx Keyboard Replacement, Speaker: 步骤 17 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement, Speaker: 步骤 17 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement, Speaker: 步骤 17 中的图像 3,3
    • Disconnect all the ribbon cables highlighted.
    • Be sure to use the plastic opening tool when flipping the switches up on the cable connectors.
  18. HP Omen 15-ax243dx Keyboard Replacement: 步骤 18 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 18 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 18 中的图像 3,3
    • Unplug the wire the connects to the speakers.
  19. HP Omen 15-ax243dx Keyboard Replacement: 步骤 19 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 19 中的图像 2,2
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #0 Phillips screwdriver.
  20. HP Omen 15-ax243dx Keyboard Replacement: 步骤 20 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 20 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 20 中的图像 3,3
  21. HP Omen 15-ax243dx Keyboard Replacement: 步骤 21 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 21 中的图像 2,2
    • Unscrew the two 1.2 mm screws holding the motherboard to the front panel using the same screwdriver.
  22. HP Omen 15-ax243dx Keyboard Replacement: 步骤 22 中的图像 1,1
    • Lift the back of the motherboard up then slide the audio cable out between the heatsink and motherboard
  23. HP Omen 15-ax243dx Keyboard Replacement: 步骤 23 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 23 中的图像 2,2
    • Lift the back of the motherboard up again and remove the charging adapter.
    • This wire is located in a tight spot. Pull it straight out and do not bend it, this will cause irreparable damage to the device.
  24. HP Omen 15-ax243dx Keyboard Replacement: 步骤 24 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 24 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 24 中的图像 3,3
    • Slowly lift up the back of the motherboard.
    • The board is friction fit at the rotation point. Be careful to lift the board around this point.
    • The board will now lift out of the device.
  25. HP Omen 15-ax243dx Keyboard Replacement: 步骤 25 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 25 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 25 中的图像 3,3
    • Lift up the keyboard panel of the device and set it back down.
    • The speaker in the top left hand corner can be taken out of its place.
  26. HP Omen 15-ax243dx Keyboard Replacement: 步骤 26 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 26 中的图像 2,2
    • Remove the tape between the two speakers
    • The left speaker can now be removed.
    • The speakers can be disposed of if needed now.
  27. HP Omen 15-ax243dx Keyboard Replacement, Keyboard: 步骤 27 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement, Keyboard: 步骤 27 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement, Keyboard: 步骤 27 中的图像 3,3
    • Use the opening tool to flip the switch that holds the cable to the power button.
    • Lift the cable out of the connector
  28. HP Omen 15-ax243dx Keyboard Replacement: 步骤 28 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 28 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 28 中的图像 3,3
    • Unscrew the two 1.2 mm #00 Phillips head screws that hold the board in.
    • This can now be lifted straight out of the device.
  29. HP Omen 15-ax243dx Keyboard Replacement: 步骤 29 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 29 中的图像 2,2
    • Unscrew the 1.2 mm #00 Phillips head screw that holds the power button into place.
    • This can be lifted out of the device
  30. HP Omen 15-ax243dx Keyboard Replacement: 步骤 30 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 30 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 30 中的图像 3,3
    • Unscrew the three 1.2 mm #00 Phillips head screws that hold in the plate below the trackpad.
    • This can be lifted out of the device.
  31. HP Omen 15-ax243dx Keyboard Replacement: 步骤 31 中的图像 1,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 31 中的图像 2,3 HP Omen 15-ax243dx Keyboard Replacement: 步骤 31 中的图像 3,3
    • Lift up the clear plastic that covers the top three screws
    • Use a size #00 Phillips head screw driver to remove the three 1.2 mm screws
    • The trackpad can now be removed from the device.
  32. HP Omen 15-ax243dx Keyboard Replacement: 步骤 32 中的图像 1,2 HP Omen 15-ax243dx Keyboard Replacement: 步骤 32 中的图像 2,2
    • The keyboard can now be slid from underneath the hinges.
    • The keyboard can be disposed of is needed.
结论
3等其他人完成本指南。
Dean Lee
于10/19/17注册
360 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G7
3 名成员
创作了7篇指南
6条评论
Do you have a link to buy the replacement keyboard?
Seth Norton - 回复
How do you take apart the keyboard compartment to replace the keyboard?
corbycobb - 回复
Very useful tutorial, thanks !
Hugo - 回复
Very useful tutorial, thanks you so much.
Ata Akkaya - 回复
If you didn't buy a keyboard yet, DON'T!
I followed this guide only to learn at the end that you CANNOT replace just the keyboard (but you CAN put a new keyboard in; keep reading). I specifically bought a keyboard after seeing this guide, and when I got it all taken apart, I learned I wasted my money and time.
This guide should make a correction at the beginning saying that you need MORE than just the keyboard!!!
You can install a new keyboard, but you need to REPLACE THE ENTIRE KEYBOARD COVER as one entire unit: speaker grill, touchpad, etc.
HP routinely designs things to screw customers, and this is a perfect example of it.
The part you need is #859735-001 (red backlit) or #905118-001 (green backlit). Depending where you buy it and how long you want to wait, it'll cost you probably 50 to 100 bucks (China-sourced). There is an unlit keyboard part, IDK the number. Or, buy the HP official part for a lot more, if you can find it.
Good luck!
Eric - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 64
总计 12,775
