当前版本的文档还未经巡查,您可以查看最新的已查核版本。
With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
Remove the rubber guards on the side of the hard drive.
Gently pull the plastic connector out from the hard drive.
The hard drive can now be disposed of if needed.
Save the guards and connectors from this hard drive, they will be used on the replacement part.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
