跳转到主内容
简介
Does your hard-drive not have enough stroage and you want to swap it for a larger storage hard-drive? Well, reading this guide will show how. To disassembly the hard-drive on this computer, it is very easy and will only take about 5 minutes. This guide includes the pre-requeste of removing the back cover and the battery. Once you the back cover and the battery, removing the hard-drive is as easy as flip, pull, lift. The tools that you will need are one, a Philips #00 screw driver and two, a blue plastic opening tool.
  1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Omen 15-ax243dx Hard-Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 2 中的图像 1,2 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 3 中的图像 1,2 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 4 中的图像 1,2 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Hard-Drive Replacement, Hard-Drive: 步骤 5 中的图像 1,1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 6 中的图像 1,3 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 6 中的图像 2,3 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 6 中的图像 3,3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 7 中的图像 1,1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 8 中的图像 1,3 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 8 中的图像 2,3 HP Omen 15-ax243dx Hard-Drive Replacement: 步骤 8 中的图像 3,3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
结论
3等其他人完成本指南。
vangnam
于2017年10月19日注册
592 声望
创作了4篇指南
团队
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 151
总计 6,114
