跳转到主内容
HP Omen 15-CE0XX Fan Replacement
你所需要的
  1. HP Omen 15-CE0XX Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the ten 5.5 mm screws from the bottom cover.
  2. HP Omen 15-CE0XX Fan Replacement: 步骤 2 中的图像 1,2 HP Omen 15-CE0XX Fan Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to gently separate the bottom cover from the main chassis, and pull the cover upwards.
  3. HP Omen 15-CE0XX Fan Replacement: 步骤 3 中的图像 1,2 HP Omen 15-CE0XX Fan Replacement: 步骤 3 中的图像 2,2
    • Unscrew the four 5.5 mm screws that connect the battery to the main system, and gently detach the battery.
    • While removing, make sure to avoid pulling the battery straight out. Instead gently lift the lower half of the battery and slide it away from the motherboard in an away and upwards motion.
  4. HP Omen 15-CE0XX Fan Replacement: 步骤 4 中的图像 1,2 HP Omen 15-CE0XX Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the trunk outlet for the replacement fan. This is done by unscrewing the three 5.5mm screws on the trunk outlet and then sliding it outwards to remove.
  5. HP Omen 15-CE0XX Fan Replacement: 步骤 5 中的图像 1,2 HP Omen 15-CE0XX Fan Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to unscrew the five 5.5 mm screws that secure the bracket to the frame.
    • After all screws are loose, gently lift the bracket upwards.
    • Be careful with the power cable sitting right under this bracket. You might have to move the cable around gently to get the bracket out
  6. HP Omen 15-CE0XX Fan Replacement: 步骤 6 中的图像 1,1
    • Disconnect the fan cable from the motherboard using a plastic opening/ pry tool.
    • Do not use too much force while pulling the fan cable as it may break. If required, you may use a secondary plastic opening/pry tool for support.
  7. HP Omen 15-CE0XX Fan Replacement: 步骤 7 中的图像 1,1
    • Carefully pull the fan out, clean the dust if required.
    • Finally, you can now replace the faulty fan with the new fan by following the above steps in reverse order.
结论
另外一个人完成了本指南。
Nadim Patel
于01/27/23注册
154 声望
撰写一个指南
团队
York University, Team P-21, Allen Winter 2023 York University, Team P-21, Allen Winter 2023 的会员
YORK-ALLEN-W23SPG21
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 23
过去 30 天: 65
总计 1,077
