跳转到主内容
HP Omen 15-5002xx Battery Replacement
你所需要的
  1. HP Omen 15-5002xx Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 HP Omen 15-5002xx Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Battery Replacement: 步骤 3 中的图像 1,2 HP Omen 15-5002xx Battery Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
结论
Eduardo Arellano
于09/01/21注册
621 声望
创作了5篇指南
团队
Gateway, Team 1-1, Saknee Fall 2021 Gateway, Team 1-1, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G1
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 565
