跳转到主内容
HP Officejet Pro 8625 Display Motherboard Replacement
你所需要的
  1. HP Officejet Pro 8625 Display Motherboard Replacement, Display Motherboard: 步骤 1 中的图像 1,2 HP Officejet Pro 8625 Display Motherboard Replacement, Display Motherboard: 步骤 1 中的图像 2,2
    • Disconnect the display by holding it in place while pulling down on the plastic hinge.
    • Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
  2. HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 2 中的图像 1,3 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 2 中的图像 2,3 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 2 中的图像 3,3
    • Lift the display as high as it will allow to expose the back of the display.
    • Pinch the sides of the cover and pull away from the printer to reveal the connector.
    • Remove the connector by pulling both away from the display and towards the printer.
  3. HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 3 中的图像 1,3 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 3 中的图像 2,3 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the four 6.2 mm T9 screws from the back of the display.
    • Pull the display assembly up and away from the printer.
  4. HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 4 中的图像 1,2 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover from the display assembly by pressing down on the point of connection.
    • If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
  5. HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 5 中的图像 1,2 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the four 4.8 mm T6 screws from the back of the display motherboard.
  6. HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 6 中的图像 1,2 HP Officejet Pro 8625 Display Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the connection on the front of the display motherboard.
    • Remove the display motherboard.
结论
Daniel
于10/08/18注册
289 声望
创作了2篇指南
团队
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 的会员
CPSU-WHITE-F18S13G3
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 232
