跳转到主内容
HP Officejet Pro 8620 Printer Head Replacement
  1. HP Officejet Pro 8620 Printer Head Replacement, Printer Head: 步骤 1 中的图像 1,1
    • Open the printer head cover door by pulling the cover door.
    • Power on the printer. This will move the print head to the left so you can access it.
    • Unplug the power cable from the back of the printer.
    • Do not power down the printer using the power button, as this will cause the printhead to move back to the right, making it incaccessible.
  2. HP Officejet Pro 8620 Printer Head Replacement: 步骤 2 中的图像 1,2 HP Officejet Pro 8620 Printer Head Replacement: 步骤 2 中的图像 2,2
    • Locate the printer head on the left side of the printer.
  3. HP Officejet Pro 8620 Printer Head Replacement: 步骤 3 中的图像 1,2 HP Officejet Pro 8620 Printer Head Replacement: 步骤 3 中的图像 2,2
    • Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
  4. HP Officejet Pro 8620 Printer Head Replacement: 步骤 4 中的图像 1,2 HP Officejet Pro 8620 Printer Head Replacement: 步骤 4 中的图像 2,2
    • Gently pull out the printer head.
结论
13等其他人完成本指南。
Scott
于01/24/18注册
593 声望
创作了3篇指南
团队
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S19G2
1 名成员
创作了6篇指南
15条评论
Did not work for me on my HP 8620.
Sam Cauchi - 回复
Do you sell the replacement print head box for the HP Officejet pro 8620?
Do you post to England?
Thanks Pat Trotter
Pat Trotter - 回复
How about always paperjam and printhead just moving by 1 inch
Setiawan Ayooservice - 回复
Replacing easy.
BUT. Can it be repaired? Someone real experience with it?
PS. Of course only as no physical damage from outside and all 4 ink chambers (1) still sealed properly and (2) never have run empty
lbruederlin - 回复
Did not work for me. Followed the instruction and re installed the printhead. Same issue.
abenani2000 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 40
过去 30 天: 196
总计 23,859
