跳转到主内容
HP Officejet Pro 8600 Plus Control Panel Replacement
你所需要的
  1. HP Officejet Pro 8600 Plus Control Panel Replacement, Control Panel: 步骤 1 中的图像 1,1
    • Lift the scanner lid to a resting position.
  2. HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool into each of the three plugs to pry them from the control panel hinge located above the control panel screen.
  3. HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the three 10mm-T10 Torx screws.
  4. HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 4 中的图像 1,1
    • Disconnect the control panel from the hinge by gently lifting upward, then outward towards you.
  5. HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 5 中的图像 1,3 HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 5 中的图像 2,3 HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 5 中的图像 3,3
    • Detach the control panel from the black plastic latch by gently lifting upward, then outward towards you.
    • Pull up on the left side when sliding up so the panel does not get stuck at the end of the track.
  6. HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 6 中的图像 1,3 HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 6 中的图像 2,3 HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 6 中的图像 3,3
    • Turn over the control panel, making the screen face downwards.
    • Place two fingers on the rectangular, plastic wire cover and squeeze inward. Slide the cover downward, away from the cables, until the cover is fully removed.
  7. HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 7 中的图像 1,2 HP Officejet Pro 8600 Plus Control Panel Replacement: 步骤 7 中的图像 2,2
    • Disconnect the two ribbon cables from the panel by pulling them upward out of their ports.
    • This does not break the cables. They can easily be reconnected by plugging them into their ports again.
结论
9等其他人完成本指南。
Mackinnon Buck
于04/18/18注册
1,182 声望
创作了3篇指南
团队
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G4
4 名成员
创作了10篇指南
4条评论
This worked pretty much exactly as described; was a fairly straightforward procedure. Just have to be super-careful with those ribbon cables - they’re pretty delicate!
Angus McAllister - 回复
This is the easy one. Please do one for the HP Officejet Pro 8610. How the !&&* do you remove the led panel. It’s maddening!
Greg Freeman - 回复
Now if only I could find a replacement panel that I can trust! Any suggestions on where to buy the part?
L R Shukla - 回复
I’ve two of these printers and the screen is shot on both of them. Very frustrating that replacement screens aren’t available. Almost looks like a planned failure????
Jon Pagh - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 83
总计 9,417
