跳转到主内容
HP Officejet Pro 6835 Sensor Chip Replacement
你所需要的
  1. HP Officejet Pro 6835 Sensor Chip Replacement, HP Officejet Pro 6835 Cover Disassembly: 步骤 1 中的图像 1,1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 2 中的图像 1,3 HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 2 中的图像 2,3 HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 2 中的图像 3,3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 3 中的图像 1,1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 4 中的图像 1,2 HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 4 中的图像 2,2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Sensor Chip Replacement, Sensor Chip: 步骤 5 中的图像 1,1
    • Twist the screwdriver counter-clockwise to remove the T9 screw on the sensor chip.
  6. HP Officejet Pro 6835 Sensor Chip Replacement: 步骤 6 中的图像 1,1
    • Pick up the sensor chip by the edges.
    • Pull the white cable to disconnect it from the sensor chip.
    • Repeat the process with the cable on the bottom.
结论
另外一个人完成了本指南。
Dimitri Charitou
于01/24/18注册
489 声望
创作了2篇指南
团队
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,011
