跳转到主内容
HP Officejet Pro 6835 Encoder Strip Replacement
你所需要的
  1. HP Officejet Pro 6835 Encoder Strip Replacement, HP Officejet Pro 6835 Cover Disassembly: 步骤 1 中的图像 1,1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 2 中的图像 1,3 HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 2 中的图像 2,3 HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 2 中的图像 3,3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 3 中的图像 1,1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 4 中的图像 1,2 HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 4 中的图像 2,2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Encoder Strip Replacement, Encoder Strip: 步骤 5 中的图像 1,2 HP Officejet Pro 6835 Encoder Strip Replacement, Encoder Strip: 步骤 5 中的图像 2,2
    • Push the hook that is attached to the encoder strip towards the center of the printer.
    • Hold the hook pushed in and pull the strip off of the hook.
    • Repeat on the other side of the encoder strip.
    • During reassembly, the black triangle on the encoder strip should be on the right side of the printer.
  6. HP Officejet Pro 6835 Encoder Strip Replacement: 步骤 6 中的图像 1,1
    • Carefully slide the encoder strip out from the carriage.
结论
David J
于01/24/18注册
169 声望
创作了2篇指南
团队
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 21
总计 1,978
