跳转到主内容
HP Officejet J4550 All-in-one Glass Plate Replacement
你所需要的
  1. HP Officejet J4550 All-in-one Glass Plate Replacement, Glass Plate: 步骤 1 中的图像 1,2 HP Officejet J4550 All-in-one Glass Plate Replacement, Glass Plate: 步骤 1 中的图像 2,2
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 2 中的图像 1,3 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 2 中的图像 2,3 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 2 中的图像 3,3
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
  3. HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 3 中的图像 1,3 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 3 中的图像 2,3 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 3 中的图像 3,3
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
  4. HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 4 中的图像 1,2 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 4 中的图像 2,2
    • Remove the controlling keyboard with hands.
  5. HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 5 中的图像 1,2 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 5 中的图像 2,2
    • Using fingers to open the back cover board of the glass plate.
  6. HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 6 中的图像 1,3 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 6 中的图像 2,3 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 6 中的图像 3,3
    • Remove the 10mm screw on the right of the board with T8 torx security screwdriver.
    • Remove the part that is under the 10mm screw.
  7. HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 7 中的图像 1,2 HP Officejet J4550 All-in-one Glass Plate Replacement: 步骤 7 中的图像 2,2
    • Remove the glass plate with hands.
结论
Jiayin Zhu
于10/21/18注册
349 声望
创作了3篇指南
团队
UC Davis, Team S11-G8, Lore Fall 2018 UC Davis, Team S11-G8, Lore Fall 2018 的会员
UCD-LORE-F18S11G8
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 180
