跳转到主内容
HP Officejet J3680 Speaker Replacement
你所需要的
  1. HP Officejet J3680 Speaker Replacement, Unplug the Device: 步骤 1 中的图像 1,1
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
  2. HP Officejet J3680 Speaker Replacement, Remove Screws From Under the Control Panel: 步骤 2 中的图像 1,1
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
  3. HP Officejet J3680 Speaker Replacement, Remove Screws Underneath the Ink Cartridge Cover: 步骤 3 中的图像 1,1
  4. HP Officejet J3680 Speaker Replacement, Remove Screws from Underneath the Phone Panel: 步骤 4 中的图像 1,1
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
  5. HP Officejet J3680 Speaker Replacement, Remove the Screws from the Rear of Device: 步骤 5 中的图像 1,1
  6. HP Officejet J3680 Speaker Replacement, Remove Rear Plastic Panel: 步骤 6 中的图像 1,1
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
  7. HP Officejet J3680 Speaker Replacement, Unscrew the speaker: 步骤 7 中的图像 1,1
    • Using your Torx t10 screwdriver, remove the screw located on the right side of the speaker as shown in the figure on the left. The screw is 13mm in length.
  8. HP Officejet J3680 Speaker Replacement, Detatch the speaker: 步骤 8 中的图像 1,1
    • Follow the wires, connected to the speaker, to the green mother board.
    • Then detach the white plastic piece connected to the wires, shown on the left, by gently pulling it out from the motherboard.
结论
Marisa
于10/22/14注册
206 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-1, Duarte Fall 2014 UMass Dartmouth, Team 1-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 288
