你所需要的
Remove the plug from the outlet and from the back of the device
Remove the USB Cable from your computer and from the back of the device.
Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
In step 2, you removed the screw from the blue indicated area.
Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
Using your Torx t10 screwdriver, remove the screw located on the right side of the speaker as shown in the figure on the left. The screw is 13mm in length.
Follow the wires, connected to the speaker, to the green mother board.
Then detach the white plastic piece connected to the wires, shown on the left, by gently pulling it out from the motherboard.
