跳转到主内容
HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement
你所需要的
  1. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Unplug the Device: 步骤 1 中的图像 1,1
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
  2. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove Screws From Under the Control Panel: 步骤 2 中的图像 1,1
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
  3. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove Screws Underneath the Ink Cartridge Cover: 步骤 3 中的图像 1,1
  4. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove Screws from Underneath the Phone Panel: 步骤 4 中的图像 1,1
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
  5. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove the Screws from the Rear of Device: 步骤 5 中的图像 1,1
  6. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove Rear Plastic Panel: 步骤 6 中的图像 1,1
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
  7. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove Green Connector from Main Motherboard: 步骤 7 中的图像 1,1
    • On the left side of the ADF Scanner Glass, you will see a green wire. Follow this wire to the main motherboard. Using your Torx T10 screwdriver, remove the screw that is holding this wire to the main motherboard. The screw is 13mm in length.
  8. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove the White Cable from the Main Motherboard: 步骤 8 中的图像 1,1
    • On the left side of the ADF Scanner Glass, you will see a white cable that leads to the main motherboard. Carefully remove this cable by pulling it straight up and out of the connector.
  9. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Remove the ADF Scanner Glass: 步骤 9 中的图像 1,1
    • With both cables removed from the main motherboard, carefully push the two grey tabs on the edges of the scanner glass inward (as shown by the arrows in the image). Carefully pull the scanner glass up and out from the device.
    • Make sure you are aware of the green and white cables, as you do not want them to get caught on anything on the device.
  10. HP Officejet J3680 Automatic Document Feeder Scanner Glass Replacement, Repeat Steps in Reverse Order to Replace the ADF Scanner Glass: 步骤 10 中的图像 1,1
    • Carefully thread the green and white cable through the device towards the main motherboard. Connect these cables back into the motherboard.
    • Carefully pop the new ADF Scanner Glass back into the device.
    • Replace the rear plastic panel, plug in your device, and test out the new ADF Scanner Glass.
结论
2等其他人完成本指南。
Evan
于10/20/14注册
388 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-1, Duarte Fall 2014 UMass Dartmouth, Team 1-1, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 1,227
