当前版本的文档还未经巡查,您可以查看最新的已查核版本。
There is a hidden screw underneath the model sticker on the front panel.
Peel the model sticker off the cover.
This will expose the T10 screw securing the panel.
Remove the single 12mm-T10 screw securing the front panel to the printer body.
Loosen the panel cover from the printer body.
There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
Remove the seven 8mm screws using the Torx T6 screwdriver.
Remove the motherboard from the front-panel housing.
The LCD display is on the opposite side.
Start with the scanner head in place.
Unwind the ribbon from the track.
Detach ribbon completely.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
