跳转到主内容
HP OfficeJet 4650 Paper Tray Replacement
你所需要的
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: 步骤 1 中的图像 1,2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: 步骤 1 中的图像 2,2
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: 步骤 2 中的图像 1,2 HP OfficeJet 4650 Paper Tray Replacement: 步骤 2 中的图像 2,2
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: 步骤 3 中的图像 1,3 HP OfficeJet 4650 Paper Tray Replacement: 步骤 3 中的图像 2,3 HP OfficeJet 4650 Paper Tray Replacement: 步骤 3 中的图像 3,3
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: 步骤 4 中的图像 1,2 HP OfficeJet 4650 Paper Tray Replacement: 步骤 4 中的图像 2,2
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: 步骤 5 中的图像 1,1
    • Remove the paper tray by pulling the tray away from the printer.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G6
3 名成员
创作了10篇指南
3条评论
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - 回复
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - 回复
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 4,543
