跳转到主内容
HP Notebook 15-ba018ds Wifi Chip Replacement
你所需要的
  1. HP Notebook 15-ba018ds Wifi Chip Replacement, Battery: 步骤 1 中的图像 1,1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 2 中的图像 1,3 HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 2 中的图像 2,3 HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 2 中的图像 3,3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: 步骤 3 中的图像 1,2 HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: 步骤 3 中的图像 2,2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 4 中的图像 1,1
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 5 中的图像 1,2 HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to remove the screw holding down the wifi chip.
  6. HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 6 中的图像 1,2 HP Notebook 15-ba018ds Wifi Chip Replacement: 步骤 6 中的图像 2,2
    • Remove the two wires connected to the wifi chip.
    • The wires are labeled 1 and 2. This is important to know when reconnecting the wires to the wifi chip.
    • Gently pull the wifi chip out and replace with a new wifi chip.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,023
