跳转到主内容
加入维修社区 - 创建账户
HP Notebook 15-ay011nr Optical Drive Replacement
你所需要的
    • Before disassembling the computer, follow these steps:
    • Shut down the computer
    • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer
    • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
    询问修复机器人
    添加评论
  1. HP Notebook 15-ay011nr Optical Drive Replacement, Removing the battery: 步骤 2 中的图像 1,1
    • To remove the battery:
    • Position the computer upside down on a flat surface
    • Slide the battery lock latch (1)
    • Slide the battery release latch (2)
    • Remove the battery (3) from the computer
    询问修复机器人
    添加评论
  2. HP Notebook 15-ay011nr Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,1
    • To remove the optical drive:
    • Remove the Philips PM2.5x6.0 screw (1)
    • Remove the optical drive (2) by sliding it out of the optical drive bay
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Alec Ringberg
于08/05/18注册
652 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 362
