跳转到主内容
HP Mobile Thin Client mt41 Optical Disc Drive Replacement
你所需要的
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 1 中的图像 1,2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 1 中的图像 2,2
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 2 中的图像 1,2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 2 中的图像 2,2
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 3 中的图像 1,3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 3 中的图像 2,3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 3 中的图像 3,3
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 4 中的图像 1,3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 4 中的图像 2,3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 步骤 4 中的图像 3,3
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 440
