跳转到主内容
HP Mobile Thin Client mt41 Fan Replacement
你所需要的
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: 步骤 2 中的图像 1,2 HP Mobile Thin Client mt41 Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: 步骤 3 中的图像 1,1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: 步骤 5 中的图像 1,2 HP Mobile Thin Client mt41 Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: 步骤 6 中的图像 1,1
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: 步骤 7 中的图像 1,1
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 19
总计 367
