跳转到主内容
HP Mobile Thin Client mt41 Charging Port Replacement
你所需要的
  1. HP Mobile Thin Client mt41 Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two slots on the bottom of the laptop to unlock the battery.
  2. HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 2 中的图像 1,2 HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
  3. HP Mobile Thin Client mt41 Charging Port Replacement, Back Cover: 步骤 3 中的图像 1,2 HP Mobile Thin Client mt41 Charging Port Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  4. HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 4 中的图像 1,2 HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  5. HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  6. HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  7. HP Mobile Thin Client mt41 Charging Port Replacement, Charging Port: 步骤 7 中的图像 1,1
    • Locate the charging port (pictured here).
  8. HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 8 中的图像 1,2 HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the T5 Torx screwdriver to remove the screw securing the charging port.
    • Remove the charging port with a pair of tweezers. Gently pull it away from the computer base.
  9. HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 9 中的图像 1,2 HP Mobile Thin Client mt41 Charging Port Replacement: 步骤 9 中的图像 2,2
    • Just below the charging port, you will find a connector with a white base and a bundle of wires.
    • Using your fingers, pull the cable directly up and away from the computer base. This should be the same direction that the wires are facing.
    • This should not require much force.
结论
Raul Rodriguez
于02/27/18注册
289 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 369
