简介
If your HP Mini 311 has ran out of memory or you desire to have more memory, change the hard drive on your device.
你所需要的
Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
即将完成!
结论
4等其他人完成本指南。
