跳转到主内容
HP Mini 210-2070NR Hard Drive Replacement
你所需要的
  1. HP Mini 210-2070NR Hard Drive Replacement, Battery and Service Access Cover: 步骤 1 中的图像 1,1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Mini 210-2070NR Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Mini 210-2070NR Hard Drive Replacement: 步骤 2 中的图像 3,3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Hard Drive Replacement: 步骤 3 中的图像 1,3 HP Mini 210-2070NR Hard Drive Replacement: 步骤 3 中的图像 2,3 HP Mini 210-2070NR Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Remove the HP product sticker.
    • Be careful not to pull up the black hard drive plastic connector with the sticker. Also, removing this sticker will void your warranty.
  6. HP Mini 210-2070NR Hard Drive Replacement: 步骤 6 中的图像 1,2 HP Mini 210-2070NR Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Locate the hard drive, where the HP Product sticker used to be.
    • Locate the hard drive cable, connected to the hard drive.
    • Disconnect the hard drive cable by gently pulling upward.
  7. HP Mini 210-2070NR Hard Drive Replacement: 步骤 7 中的图像 1,2 HP Mini 210-2070NR Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Using a #00 Phillips screwdriver, unscrew and remove the three 2.0 x 4.0 Philips screws holding the hard drive in place.
  8. HP Mini 210-2070NR Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Mini 210-2070NR Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Use the Mylar Tab located on the right side of the hard drive to pry up the hard drive.
    • Remove the hard drive.
  9. HP Mini 210-2070NR Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Lay the hard drive down with the underside facing up.
    • Pull and remove the hard drive pin connector from the hard drive.
结论
4等其他人完成本指南。
Alek Linquist
于10/05/12注册
123 声望
创作了2篇指南
团队
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G23
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 2,258
