跳转到主内容
HP Mini 210-1199DX Wireless Card Replacement
你所需要的
  1. HP Mini 210-1199DX Wireless Card Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210-1199DX Wireless Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Wireless Card Replacement, Bottom Cover: 步骤 3 中的图像 1,1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Wireless Card Replacement: 步骤 4 中的图像 1,3 HP Mini 210-1199DX Wireless Card Replacement: 步骤 4 中的图像 2,3 HP Mini 210-1199DX Wireless Card Replacement: 步骤 4 中的图像 3,3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Pull the case off of the device
  6. HP Mini 210-1199DX Wireless Card Replacement, Wireless Card: 步骤 6 中的图像 1,1
    • Locate the Wireless Card.
  7. HP Mini 210-1199DX Wireless Card Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • With fingers or tweezers, carefully pull the black and white wire connectors from their sockets and move them to the side.
  8. HP Mini 210-1199DX Wireless Card Replacement: 步骤 8 中的图像 1,2 HP Mini 210-1199DX Wireless Card Replacement: 步骤 8 中的图像 2,2
    • With a Phillip's Screwdriver, firmly but slowly remove the two screws from the top of the wireless card.
    • Be careful not to strip the nail head.
  9. HP Mini 210-1199DX Wireless Card Replacement: 步骤 9 中的图像 1,1
    • Pull the wireless card out.
结论
Phillip Winston
于03/21/17注册
655 声望
创作了6篇指南
团队
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 423
