跳转到主内容
HP Mini 210-1199DX Bottom Cover Replacement
你所需要的
  1. HP Mini 210-1199DX Bottom Cover Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210-1199DX Bottom Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Bottom Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Bottom Cover Replacement, Bottom Cover: 步骤 3 中的图像 1,1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Bottom Cover Replacement: 步骤 4 中的图像 1,3 HP Mini 210-1199DX Bottom Cover Replacement: 步骤 4 中的图像 2,3 HP Mini 210-1199DX Bottom Cover Replacement: 步骤 4 中的图像 3,3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Bottom Cover Replacement: 步骤 5 中的图像 1,1
    • Pull the case off of the device
结论
Phillip Winston
于03/21/17注册
655 声望
创作了6篇指南
团队
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G3
3 名成员
创作了6篇指南
一条评论
Awesome tip about the release buttons. Once I got it off I noted the eject latch only runs halfway down the device and the rubber feet are actually attached to the frame not the bottom cover which just has holes for them to protrude through.
I wanted to get the bottom off in order to verify the AC adapter Voltage, Amperage and Polarity (which I think ios the same for the whole 210 line.
I guess I’ll upgrade to an SSD and increase the RAM while it’s open..
Power specs for my model: HP Mini 210 1075CA: 19.5Vdc, 2.05A, with polarity being ++''inside & - -''outside .
osearth esp - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 284
