跳转到主内容
HP Mini 210 WiFi Card Replacement
你所需要的
  1. HP Mini 210 WiFi Card Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210 WiFi Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 WiFi Card Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
  3. HP Mini 210 WiFi Card Replacement, Disassembling HP Mini 210 Back Case: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 WiFi Card Replacement: 步骤 4 中的图像 1,1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 WiFi Card Replacement: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
  6. HP Mini 210 WiFi Card Replacement, WiFi Card: 步骤 6 中的图像 1,1
    • Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
  7. HP Mini 210 WiFi Card Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
  8. HP Mini 210 WiFi Card Replacement: 步骤 8 中的图像 1,1
    • Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
结论
另外一个人完成了本指南。
Heather Freed
于10/06/12注册
723 声望
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 5,358
